atreis
Sep 18, 2013Explorer
I use the one with the optional signal amplifier for OTA HD TV here at home. "Home" in this case, is about 30 miles from the broadcast towers in my area, just for a reference point, over basically flat ground. It works GREAT. I get all of the local stations perfectly clearly, and can even pick up some (albeit with noise) from more distant cities.
In terms of use, I had to fiddle with it some - move it around to different spots - to find a good location. It's now on the wall about 2 feet above, and slightly to the left, of my TV. In terms of RV use, that would probably be the biggest annoyance. You'd have to fiddle with it at each location you stop at.
