Bumpyroad
Apr 13, 2014Explorer
Heavy Metal Doctor wrote:
And the flush system is a permanently installed part that came with the unit. Nothing more than a hose connection on the outside that runs to a nozzle mounted inside the black tank.
how often do you use that sprayer? every time you dump your tank? how often is that? if you had overflow into the bathroom, you way overfilled things.
and when using ice, do not use a lot of water as if you do all the ice will do is bob along in the water. let the ice slide along the bottom of the tank, and bang into "stuff".
bumpy
