Heavy_Metal_Doc
Apr 13, 2014Explorer
Bumpyroad wrote:
your flusher system is somehow connected to the sink inside the RV? a very strange hookup. and the antiflow valve will leak when shut off as a little water will drain back from the "clean" side.
Not connected to the sink system in any way, that is just where they mounted the the antiflow valve. The outside connection is on that wall and runs inside the cabinet bellow the bathroom sink, then to this valve, and on down through the floor to the black tank.
So, you're saying I should be prepared for this valve to drip a little each time you shut it off? I know mine is messed up because it drips all the time when the water it is on.
