Bumpyroad
Apr 15, 2014Explorer
Lynnmor wrote:Bumpyroad wrote:Heavy Metal Doctor wrote:
Not connected to the sink system in any way, that is just where they mounted the the antiflow valve. The outside connection is on that wall and runs inside the cabinet bellow the bathroom sink, then to this valve, and on down through the floor to the black tank.
So, you're saying I should be prepared for this valve to drip a little each time you shut it off? I know mine is messed up because it drips all the time when the water it is on.
that doesn't make any sense to me. perhaps somebody with the same RV can add something here. every screw on the hose end anti backflow valves that I have used do squirt out water when the water is shut off. wouldn't think they would put such a valve inside a RV however.
bumpy
The valve will expel water, see page 11.
interesting, thanks, I still don't see how that is an "improvement" to the old way. I'd still use another anti backflow device on the feed hose.
bumpy
