time2roll wrote:
You have a lot of stuff going on.  My solution with electrical issues is to divide and conquer.
You have at least three components in play.  Two batteries and a converter that all provide 12 volt nominal power.
First disconnect one terminal at each battery and plug in the main cord.  The converter should provide about 13.6 volts very steady.  All systems should work.
Assuming that works connect the two batteries and let them charge 72 hours.  Check twice a day for excessive heat or gassing that would indicate a shorted cell.  Voltage should be same as the converter at about 13.6 volts right on the battery terminals.  If batteries are low on charge the voltage should steadily climb to 13.6 volts over 2 to 6 hours.
Assuming that all seems good disconnect the batteries again and monitor the battery voltage disconnected for several days.  Battery voltage should drop from 13.6 volts to 12.65 in about a day and then hold for at least three more days.
Post the results and we can go from there.
I have not posted results yet as I was delayed by an incident. Someone ran into the back of the camper and left without leaving a note (hit and run). I've been learning about insurance this week.  :(  I think the camper will be ok, but it really messed up the left rear compartment the jack is attached to.
I'm assuming it can be fixed, so the results so far:
 * the converter provides a steady 13.8v. All systems functional.
 * the batteries were charged until this morning (4 days) when I disconnected from ground power and drove to the insurance adjuster. The batteries should have been maintained during transit at 2A.  The combined batteries were providing 11.8-12.0v after 2 hours unplugged.
I will charge the batteries again and perform the proper tests.
One other thing that I've noticed that's probably unrelated and maybe a non-issue.  Most of the time when I plug in to the house, I pop the house breaker.  I'm connecting the camper to a 25' 10ga extension cord (fed under garage door), then to an outlet inside the garage, which runs to the main panel with a GFCI breaker.  I can reset the breaker and if it stays set, it will never pop again while it's connected.
