After learning a certain oil change facility does not always change the oil filter when doing an oil change I went back to doing it myself. Things have changed on the motor oil shelf. So many choice...
mix and match, change up if you like. Today's it's an old wives tale, that actually had a basis of fact in the past.
Friend was a mechanic that had a car come in with a failed engine. A little thick sludge came out of the drain. After an investigation, turns out the female owner religiously took her car to the same quickie oil change place for an oil change every 3000 miles... except for (IRC) 50,000 miles, it never got changed.
