Oasisbob
Dec 09, 2019Explorer
MOTOR OIL ?
After learning a certain oil change facility does not always change the oil filter when doing an oil change I went back to doing it myself. Things have changed on the motor oil shelf. So many choice...
Cummins12V98 wrote:blofgren wrote:BenK wrote:
Time to research engine oil filters again.
Wonder what the best/better filters spec is for particulate size they filter down to
IIRC, WIX (Napa Gold) and PureOne were good to >25 microns. Anyone have that data?
We were using WIX at work and had 2 of them leak; 1 very badly that almost took out the engine on the truck. We went back to Motorcraft and haven't had an issue since. I only use OEM on my vehicles (Fleetguard on the Ram, AC Delco on the Yukon, and Honda on the MDX.) I think the peace of mind is worth it for the little bit extra.
If you want an even better filter for your RAM look into the AMZ/OIL - Donaldson Blue. Same filter Made in USA. The FleetGuard Stratapore unfortunately is now made in Mexico.
