harmanrk wrote:
JRscooby wrote:
Not to say anything about the oil, but a 5 gallon bucket of oil? I change mine every 3 months and it takes 5 qts. That means from the time I open the jug until I put the last in the engine is 9 months. And another 3 months I'm expecting it to protect my engine. (For a while I would buy a 55 gal drum, leave drum in pickup, put a MT in with it. Could back up to a truck, pump new oil in the engine. Dump drain pans into the MT, and never need to move a full barrel.)
I five gallon bucket of oil is not at all out of the question. Modern Diesels in the larger pickups are 13 quarts (+/-). That's over 3 gallons per change. Also keeps in mind there are markets for oil in tractors and heavy trucks where 5 gallons is not a complete change.
Grit dog wrote:
So what’s the point Scooby? You buy 55gal drums of oil for your (old) gasser every 3 months because you either put on a lot of miles or have OOCCD , obsessive oil change compulsive disorder. (Likely since you through in the snippet about temperature matching the plug to the pan, lol)
But somehow this downplays someone who’s attempting to help by posting a good deal on oil in bulk?
Just cause you’re used to semis, hardly no one else buys drums of oil for personal use.
So why the negativity?
I posted that when I was using a lot of oil each change, I would buy it in a big drum. And maybe if I had a little 13 QT diesel I would think about a 5 gallon bucket. But more likely I would by a case of 6 one gallon jugs. Getting a low price on good oil is not a bargain if there is a chance the oil will be contaminated before it is used. Is it negative to point out this might be a issue? After all some people like to drop the oil out of a engine that has been unused all winter before they take a trip...
As for " Likely since you through in the snippet about temperature matching the plug to the pan, lol)" let's look at
harmanrk wrote:
As for oil place horror stories, mine is pretty straightforward. Lived in an apartment for a while and could not change my own so had to use a quick lube. Bought a house, and on the first time changing the oil in my garage, had a the threads from the Aluminum pan attached to the steel plug. I'm not saying the tech (pimple faced highschooler) in the pit CAN'T do it right, just as other have said, at 8 buck an hour, they don't care about my car, as much as I do.
I have also had issues with threads in pan, cracks around the drain hole, used cheater pipe or mpact because my wrench was not long enough, after I had others change oil for me, or did not take that extra few minutes. Sure steel will seize to aluminum, and you can heat the aluminum around the plug to help it release, but I think that the colder plug tightened into the pan makes it worse. I never have had a issue when I put the plug in finger tight, put new oil in the engine, then tightened the plug.
