- CAJWExplorer
fpoole wrote:
CAJW wrote:
...so I rigged up some coated 1/4" cable with sailboat quick release adjustable turnbuckles to semi-support the carrier. I attached the upper ends to the camper jack mount bolts and the lower ends to the carrier rail. Works well and I'm sure that if I wanted, I could add a bicycle carrier to the mix.
Kewl, that's what I was looking for.. how to attach it to the camper without drilling etc... nice...
Thanks...
The next time I load up the bike, I'll shoot some pics and provide parts sources (that is if I can find my receipts).
Here's the quick release I used that works slick. Quick release
I used something like this to attach the cables to the camper jack bolts. Eye nut - notevenExplorer IIISuper hitches n trusses are stout:
- notevenExplorer IIILook at VersaHaul website for their stainless dealie that pinch-bolts the bike carrier at the receiver to stop the flopping and rocking.
- fpooleExplorer
Thanks... - CAJWExplorerI carry my dirt bike on a carrier plugged into my Torklift 32" Superhitch extension. I'd contacted Torklift to clarify the tongue weight ratings, figured the arm, multiplied the weight and still have a healthy margin for safety. The one thing I didn't like was the side to side rocking of the carrier, so I rigged up some coated 1/4" cable with sailboat quick release adjustable turnbuckles to semi-support the carrier. I attached the upper ends to the camper jack mount bolts and the lower ends to the carrier rail. Works well and I'm sure that if I wanted, I could add a bicycle carrier to the mix.
As a side note to the OP, is it an optical illusion in the third picture of your post or is your Arctic Fox camper setting a bit tail low? - GeoBoyExplorerWe have 2 - 12' long solo canoes that we have to tow because I am not climbing up on my TC roof to load and unload them. So we purchased a Dock Doctors paddle sport aluminum trailer to haul them, I also installed 2 skewer mounts in a piece of aluminum channel that spans the width of the trailer. So now I can carry our bikes and canoes, and if I get into a jam I can unhitch the trailer and quickly move it around by hand.
- Reddog1Explorer III cannot imagine that the Superhitch would fail. The extensions maybe. In my case it was the bike rack that failed. The whiping action ripped the tubing. The welds were okay as was the extension.
- I couldn't begin to fathom having that much weight/leverage on my hitch and Supertruss. Something is going to break eventually, Like Wayne mentioned about losing bikes.
A trailer might seem like a nuisance, but to me it isn't. I've towed with it long enough, it's second nature driving with it back there. - jspringatorExplorerI can't tell if you have anything mounted on the front, but I carried a XT225 on the front of my Excursion while towing for years. Worked out pretty well.
- Fisher_BillExplorerSo you have a superhitch with a super TRUSS plugged in, mine is a 42" extension and I also have the two turnbuckles going from the end of the super Truss back to the super hitch.
I also have a front receiver and I was planning on putting a motorcycle up front and then making my basket first on the back and incorporating the bike rack to the basket so I can carry the 3500W genny and another tub with the bike behind the basket.
With the single hitch you have coming from the super truss that is supported by turnbuckles still looks to be a weak point to me because of over extension.
If the math works out then fine but I think there could be some leveraged points with the weight of the bike moved so far back.
Good luck and time will tell.
Bill
