martinto's avatar
martinto
Mountain grades
Heading up to the Smokies near Cherokee, NC. I have a Yukon Denali with 6.2l and HD tow pfg. Pulling a 26 ft Crossroads Slingshot. With our gear, it may weigh in about 5000 lbs. +/- a couple hundred lbs. I always pull in tow mode but most trips were in Texas until I moved to SC. In Texas Hill Country the hills don't have the grades we will see in the Smokies. So, my question...does the tow mode compensate for steep grades or do I still need to downshift manually? I expect I will feel the stress on the rpm's and shift accordingly. But was wondering what others may have experienced.
  • Supercharged is right, the Smokies aren't bad at all, just wait until you get to the Rockies!
  • Apply pressure to the foot pedal on the right hand side of your tow vehicle . The truck will shift when it needs to .
    Those are all baby hills eastern US. You should pull them in the highest gear.
    Depending on how you get there, There aren't any really bad grades from the South. Saluda Grade on I-26 is about the worst, until you get off the main roads.
    So depending on your TV. Going up will be the easy part. Coming down is always the hard part. So when you do, and you have a gas engine. Gear down to no higher than 2nd, and if that lets you go too fast. Gear down to 1st. Find a gear that will hold the speed you want to come down at.
    If you have a diesel. Some will hold the TV back in tow haul. If not, Use a exhaust brake, or trany brake. Or just go down real slow.
