Butch50
Jun 14, 2014Explorer
jimh425 wrote:
Mine is in the standard location under bed since I have a normal pickup bed. The mechanism is available if you wanted to do something similar to add the winch to yours and not expensive.
That works on you truck but it won't work on a chassis cab model. Yours is built as a pickup but on the C&C that is the location of the main 40 gallon fuel tank. So it hangs down low if you tried to install a tire below it the tire would almost be on the ground.
