browntljm's avatar
browntljm
Mouse activity
My daughter and son in-law have a Spree Connect 322BHS, and they have had to store it short term at a farm house. After about two months of storage, upon inspection, mice were discovered inhabiting. I was curious to know if anyone would know where I could find a print of the floor, exhibiting the wholes for plumbing and electrical, so that caulking or whatever mending can be done on the inside, since the underbelly is inclosed.
  • I wish I could tell you where to find some detailed plans. However, a good start would be where the fresh water pump is (normally very close or above the fresh water tank). Another place is at the hot water heater. That of course will be just inside behind the exterior access for the w/h. You may have to remove a few screws to open a panel or two. At each of these locations you will probably see a hole cut in the floor to run the water lines etc.
  • Lots of sticky traps. There are literally dozens of access points for a mouse in any RV. And if they sense food they will make a hole if necessary.
