BurbMan's avatar
BurbMan
Explorer III
May 01, 2019
Moving a Broken Power Seat?
I know we have a lot of talented techs and resourceful DIYers on the forum here, so thought this would be a good place to ask this question....
A few months ago, I lost the power functions on the driver's seat. Passenger seat is fine, driver's won't move. I replaced the switch, didn't fix the problem.
Last night I got out the test light and multimeter and found the problem: the power/ground connector came unplugged from the power seat module under the seat. In the process of trying to reconnect it, the connector broke off of the circuit board on the module.
I tried jumpering power directly to the seat switch and no dice...it must come through the module.
Here's the dilemma: I need to remove the seat to change the module. The factory service manual says there are 4 bolts holding the seat, remove the front 2 then move the seat all the way forward and remove the rear 2. The problem is, the seat won't move without the module connected, and there is no way to get to the rear bolts without moving the seat forward.
I have Googled this till I was cross-eyed and have not found a workaround for this. Is there a way to change the module without removing the seat? Any GM techs here?
  • Could you some how connect a different module (junkyard?) temporarily to get the seat to move? I haven’t looked at my seat to see exactly what you’re talking about...just throwing out an idea.
