Sport45
Feb 17, 2015Explorer II
gijoecam wrote:
Touched a nerve, did I? Because it's not conceivable that an analog gauge could be off a touch? Well then clearly the digital rev counter from the ECU in my truck is off, and obviously the GPS speed is a couple mph off the gauge, so the satellites must be out of alignment or something...
Gauges are inaccurate. Calculated values based on erroneous values compound the error.
My point was simply that there could be differences between your truck and the one in the test that explain the difference in rpm at a given speed. Your gauge could be off a bit low and the tested truck's could be off a thick high. You could have slightly larger tires or your tires could, for whatever reason, have a slightly larger rolling circumference, or any of a plethora of other differences.
It's been a long time since I saw an analog gauge (except possibly the voltmeter) in any new vehicle. The pointer is typically driven by a stepper motor and points wherever the computer tells it to.You'll see some do a full sweep on startup. Possibly a self-calibration?
44,070 PostsLatest Activity: Aug 05, 2026
