Whoo hoo! We got our camper, and it is awesome! I have a few questions:
-When I drive it (this is my first camper) it seems the overhead part shifts around a bit, I would have guessed it would be tight and not sway much at all.
-The heater fan doesn't work, any ideas where to start getting that fixed?
-None of the plugs work when it is just run on the battery, is that normal?
-Should I run the fridge on propane if I am not plugged in electrically?
-Should I drain my water tank each time I use it, or will it last a while in there?
Thanks in advance, your help has been invaluable so far!!
Jeff
