bka0721
Aug 27, 2013Explorer II
recycler wrote:Looking at you sketch and seeing you live in the Rust Belt, I just wonder if you can really build a Service Body cheaper than you can get one delivered from a catalog. With materials, hinges, seals, rust prevention cladding, powder coating, location to assemble and jigs all come with a price. I will look forward to watching your project move forward. I am also interested in how you work around the EPA regs in putting a non conforming engine into a Ford truck, living in a state with strict emissions. Personally it would be great to see a Cummins in your F550.
did a rough sketch for a home built hauler body for the f550..
the body would be tapered in toward the front at the end of the opening for the forward doors..spare tire would go in the middle toward the front pass through behind it..the little rectangle under middle door is a turn signal as the truck is getting converted to have seperate brake/turn/running lights..would be built of steel tubing and sheet steel
44,071 PostsLatest Activity: Aug 16, 2026
