captnjack wrote:
bobndot wrote:
People that have slide outs feel the need to have them regardless.
They feel, all things have the potential to break or malfunction.
It's personal choice. People that feel the need to have more room, have slides.
There are owners who never have slide out issues but the potential is there and I can only describe what the negatives can be.
They add weight.
An average slide is about 500-700# and it's non-usable weight. Some larger slides are 1200-1600#. That's another problem in designing the coach. All that weight is on one side which builders compensate by adding additional slides to the opposite side.
***be careful with slides with kitchen, they have to build them with flexible lines which are often problematic.
To offset the slide out weight on one side of the rv, they then add more slides to the opposite side. Now you have 2,3 or 4 of NOT the most reliable 12v motors, seals and rails to deal with. As you add more slides, it's simply common sense that your chances increase to have problems.
All this adds up to weight and it cuts into the gross weight rating on the coach.
The RV industry, has to keep things as light as possible in order to sell them to potential buyers who tow with daily driver vehicles . (multi use vehicles, like suv's and 1500 trucks) Its difficult to add the weight of a large slide then beef up the axles, tires, wheels and frames to accommodate that weight. Only a few people would be able to tow them. Other components can suffer because they skimp in other areas to offset that weight.
Slide outs offer better resale, they initially cost more, so that offsets the resale a bit.
Extended warranties cost more. Contrary to some owners experience, many slide outs and their surrounding structures do break down, therefore warranties cost more.
People that have problems with slides, often sell the rv and start over. (and usually buy a new rv with more slides :? )
Many people report that they do not have issues but , a percentage of them don't even know they have an issue because they never take their RV apart to make any type of repair. Many owners simply don't know. They have no mechanical idea what they are towing or driving.
Not knocking them, they just don't know. Sometimes leaks get discovered once things get opened up and what a surprise can be seen on their faces.
RV's must be level to use slides. I have seen rv's with filon cracks and splits from people using them off level. Filon repairs are in the many thousands of dollars. People blame the filon when it was themselves that caused the problem by racking the structural framework.
Cold weather (hot weather too for that matter)
They have less insulation than the rest of the coach.
I found this to be my deal breaker because i use my RV's in the winter. They are colder due to less insulation and use a lot more propane...a lot more. You really realize how much colder they are when you get down to the low single digits . All my NON slide rv's were warmer, much warmer.
Most everyone i see using them in cold temps, end up building wood structures around the slide to insulate it. It also keeps the snow and ice off its weak roof. (you must climb up to clear it's roof of ice before you close it, slide awnings make it worse and its one more thing to break) .
How do they add "unusable" weight? I find them to be very usable. To get more square footage without a slide you would have to go longer. That adds weight too.
Not true that every slide needs another slide on opposite side for balance.
Unknown problems are like potential problems. We can only discuss what we know about. The rest is speculation until it happens. This is true about all areas of RV's, not just slides.
The "unusable weight" that bobndot mentions is the additional structural weight REQUIRED to reinforce that super sized hole in the side of the trailer and the duplicated structural weight of the top, bottom and sides of the slide.. Not to mention additional weight of the slide motor/slides and mechanical parts..
Those weights you cannot feel, see or smell but they are there, are real and add considerable weight to the base empty weight AND often reduce the cargo weight (IE the weight of stuff you can add to the trailer.
While I would agree that slides can make a RV "feel" bigger, BUT they also add additional downsides of LEAKING (and don't tell me that there is no posts ever on RV.net about leaking slides and how to fix the damage), motors quitting/breaking gears, hydraulic slides failing to work and complex wire slide systems breaking wires (which are buried inside the walls).
I intentionally buy non slides trailers, to me the point of camping is not to have a luxurious hotel suite, I like traveling light and pack light and find that it is a non issue not having slides..
As far as kids goes, now days they don't seem to care either, just give them a tablet or smart phone with WiFi access and you will never see or hear from them until it is meal time.. Recently at a beach I witnessed too many people walking on the beach with tablets and phones in hand staring at them while walking totally ignoring the beautiful sea and sandscapes right in full view of them :h
One year when camping, I knew I made a good decision of not having slides when I saw a fellow camper spending his entire week trying to beat his slide into submission with a hammer and wrenches..
This year I watched a fellow camper take several painful hrs in trying to get their 32ft triple slide trailer into a site meant for 26ft trailers with no slides..
Myself, only took one backup and I was ready to disconnect and setup..
