bricetribe
Feb 26, 2015Explorer
Sorry for the delay! If this were my only project I would have been done months ago. It seems like every time I get back to working on the camper I spend half the time reorganizing my plans. I also have a tendency to add to projects including a water heater replacement. I removed the OEM water heater and replaced it with a direct fit suburban water heater with the remote ignition control. Here are some pictures of the work.
The old heater:
The new heater:
The Empty hole to be filled with the new heater:
The switch installed:
The control box installed:
http://i1314.photobucket.com/albums/t572/bricetribe/20150117_183236_zpsf03wexxu.jpg
The outside after installation but prior to the door being installed:
I had more painting to do so the final installation is pending...
I ordered a new radio to replace the OEM analog radio/tapedeck which was excellent at blaring static.... should be here soon!
The old heater:
The new heater:
44,066 PostsLatest Activity: May 16, 2026
