Chuck_thehammer
Dec 11, 2013Explorer
if you truck has an upstream O2 sensor and a downstream O2 sensor.. you will not get a lean burn code and it being a 02 sensor. as one is checked off the other one. when engine is started COLD.
as the converter does no work cold. so exhaust in is the same as exhaust out.
but it could be a dirty mass AIR flow sensor.. clean it first.. otherwise replace.
44,056 PostsLatest Activity: Nov 19, 2013
