BFL13
Jan 11, 2022Explorer II
beergardens wrote:
You need to open both doors and the hood fully for diagnostic access, then disable all the door/hood ajar switches so the vehicle thinks they’re closed. Then you need to disconnect the battery and put your ammeter in series. After that is all done, you need to walk away for an hour so everything times out, keeping in mind that if you open a door or a connection, you’re going to wake everything up again and your reading will no longer be accurate.
Goodness!
It also has two back half doors, but anyway, except to open at first to pop the hood why do I have to leave the doors open and then fool them? Why not just close them?
Where is the hood's ajar switch? Edit--like this with the plug-in?
(no idea why it is in Spanish :) )
https://www.amazon.com/-/es/Dorman-820-200-Conjunto-pestillo-para/dp/B01LREVJPM/ref=sr_1_3?__mk_es_US=%C3%85M%C3%85%C5%BD%C3%95%C3%91&crid=19EOTZBYNBQK7&keywords=Dorman-820-200-Hood-Latch-Assembly&qid=1641963560&sprefix=dorman-820-200-hood-latch-assembly%2Caps%2C150&sr=8-3
I can use clamps on the meter leads so I can leave it connected like that.
To save meter battery can I turn the meter off and it is still making a path in series or does it have to be left on reading amps while waiting that hour?
