wnjj
Jul 09, 2021Explorer II
MN Ben wrote:
There is no dent. Id doesn't look scratched. It is worn or rubbed smooth.
That makes me think it was just barely in contact and the slack in the jack mounting when stowed was enough to sit and rub with light pressure. Can the jack ever get any closer? I see they lift up to pivot before dropping down. If you hold it up out of the lock slot, can it move any closer to the truck?
The truck cab and bed move much more independently than you might expect. Did you drive through something slow but twisty (like up an angled driveway cut)?
Even with snug tie-downs campers will shift in the bed. Did you drive through any strong crosswinds?
