silverbullet555
Jul 10, 2021Explorer
MN Ben wrote:silverbullet555 wrote:
Your trailer is rocking back and forth in the bed which is independent of the cab, or the cab is rocking back and forth. In either case, the body bushings are where it's likely rocking and it is moving enough to make contact. Could be cab is moving one way and camper the other on rough roads, over bumps, etc.
Even with the Fast Guns attached? It happened on one side but not the other.
Yeah. I'm not sure why. Loaded to the side, crooked, etc. The fast guns are better than bed mount in my opinion, but there is still movement of the bed and cab.
If this is new damage, think back to your last trip. Rough, washboard, bumpy roads. High winds while driving, etc. Maybe the cab moved and the camper stayed. They are on separate body mounts and I've watched ours move quite a bit in relation to each other.
It's clear where the damage occurred from. We are trying to solve why and how.
