jimh406
Jul 10, 2021Explorer III
MORSNOW wrote:
Your issue shows the big weakness with TorkLift tie downs. The anchor points are almost vertical with most trucks/campers so they don't hold the camper from dancing around in the truck box (left/right, front/back). You need more triangulation to hold the camper from moving any direction in the truck box. HappiJac gets beat up here many times, but their holding angles are far superior and your camper stays put.
If what you said was true, all of us with Torklift tie downs would have the same issue. But, we don’t. There is literally only and inch or two left over for most TCs in between the wheel wells no matter what brand of tie downs you use. It could be possible that the OP doesn’t have their fastguns adjusted correctly.
I’ll stick with this is a case of the DRW hinge being mounted wrong, so it is far too close to the body.
