- jimh406Explorer IIIMaybe swap sides for the brackets. Pictures would help since it’s hard to pause the video to see it clearly, for me.
- MN_BenExplorer
silverbullet555 wrote:
Your trailer is rocking back and forth in the bed which is independent of the cab, or the cab is rocking back and forth. In either case, the body bushings are where it's likely rocking and it is moving enough to make contact. Could be cab is moving one way and camper the other on rough roads, over bumps, etc.
Even with the Fast Guns attached? It happened on one side but not the other. - jimh406Explorer IIILooks to me like the DRW brackets are installed wrong. They should be parallel to the TC sides, but appear to angled toward the cab.
Btw, it’s normal for the TC to move side to side some. You just have minimal clearance. - silverbullet555ExplorerYour trailer is rocking back and forth in the bed which is independent of the cab, or the cab is rocking back and forth. In either case, the body bushings are where it's likely rocking and it is moving enough to make contact. Could be cab is moving one way and camper the other on rough roads, over bumps, etc.
44,055 PostsLatest Activity: Dec 23, 2025
