thomasmnile wrote:
Stealership just called, the water pump is indeed deceased. Wound up going there because when i fired it up this morning the leak became REAL obvious and it sounded like a bunch of birds chirping under the hood. Just didn't want to risk the drive to Orlando. Service advisor said replacement will be an OE part, not re manufactured or aftermarket. They are also researching the FCA tech database to answer my question regarding a TSB on this MY with the 5.9 having pulley/belt alignment issues.
For fun ask them to show you where the pump was made! Be prepared to bend way over when paying for that pump.
