RDMueller's avatar
RDMueller
Narrow driveway, pull in or back in?
Just brought home the new Wildwood 28' TT yesterday! I knew getting into the driveway would be tight and sure enough, despite turning as wide as I could, the trailer's tires cut the corner thru the grass leaving ruts. The driveway is long but narrow (10' wide) and is perpendicular to the street. The street is a typical neighborhood street, probably about 25' wide. Not helping the problem, my truck is the long bed crew cab Ram, over 20' in length.
Obviously one option is to widen the driveway near the street or put down pavers, but I'm wondering if in a situation like this, if backing might work? I'm new to pulling something this big, so there was no way I was going to try backing in without practicing in an open parking lot first. I'm just wondering if the geometry is such that, when I get good enough at backing, that doing so will allow me to get into a narrow drive when pulling in won't (at least not without leaving the pavement).
I will say, with this truck as long as it is, if parking in a tight parking lot with little room to maneuver and parking between two occupied spaces, I find it much easier to back into the space. If you try to pull in, there is just no way to get the back end over. I have no idea if the same principal would apply when towing or not.
I will probably try making chalk outlines with the exact dimensions in an empty parking lot to try it. But in the mean time, any advice would be great!
  • I have a very narrow & steep driveway and found it much easier to back into the driveway and drive out. My first attempt to do it the other way turned into a disaster. There's much more room to maneuver the truck to make the turn in the street that there is in the driveway while backing into the street.
  • In a perfect world, you will dodge and hit the exact same locations if you are pulling the trailer forward or pushing it backward. Your truck still has the same turning radius going either direction, and your trailer is still the same length. The difference is that while backing up, you can jackknife the trailer and push a short distance before you need to pull forward to straighten out the truck and continue your backing up.
    If you can back it in, you can pull it out. And if you can pull it in, it can be backed out. I feel that it is easier to pull in to a tight spot, but you still gotta get out of there.
    An option is to use a front mounted receiver hitch on the truck. This increases the maneuverability of the truck/trailer combo because you can now swing the tongue of the trailer faster by steering the truck.
    Before I was able to widen my gate I HAD to use my front hitch to get my trailer in to the side yard. I'm at the end of a cul-de-sac so my lot is pie shaped, and I have a fire hydrant in the corner of my driveway. I must dodge the hydrant, then back at an angle to miss the overhang of my garage, then pivot back to keep the trailer from hitting the gate. I couldn't do it with an ex cab short bed truck from the rear. Now I can pull my trailer in/out using the rear hitch of my crew/long truck. It just goes to show the added maneuverability.
  • I have a similar issue. There's a drainage ditch that runs in front of my house and the driveway is only about 12 feet wide. I back in and drive out. It's better than driving in and finding out you can't back out.
