saboken's avatar
saboken
Need advice before I pick up my TT It's a 750 tow
Hi I have a lot of experience towing cars with medium duty trucks but I am just about to hopefully go full time in a 2005 Gulf stream Conquest 30bhs my tow vehicle is a 2001 GMC YUKON XL slt it has the factory tow package with the factory Trans cooler and I will be using a prodigy P2 brake controller, I have a 10000lb Weight distribution system with anti sway,I used it for my former setup a 92 jeep Cherokee 4.0 and a 84 Sunline 21ft TT. MY QUESTION is now that I am upgrading is my setup safe? The Yukon says it can tow 8600 without a WD, the gulfstream weights 6622lb empty, in the math I did I have a 2392 limit I can put into the TT without going over the abilities of the Yukon, I don't plan on going over that even with the WD, I have been reading horror stories about TT's my size being towed by 1500 series trucks am I ok with this setup? I eventually want to travel from the east coast to the west coast, my main concern right now is the tow from central NJ to NW South Carolina, I have a little time I will pick it up Jan 3 2016 weather permitting. Any advice will help. Like I said towing was my life but this is my first SUV my work trucks were all F450s,F550s, INTERNATIONALS, Etc with either dedicated Jerr-Dan lifts or flat bed rollback with tow stingers, my Yukon factory hitch seems to be on the light side (the tube is thin and only attached by a few bolts) it's in good shape it just looks light to be rated up to 12000lbs! Thanks for any help I feel like a newb asking but better safe than sorry.
I added a few links to photos of the Yukon and weight stickers
and a few shots of the condition of the Yukon underside She has 270000 miles on her but runs and handles like new I doubt its the original engine and trans She is just to clean
She also has Nivomat self leveling shocks on the rear that seem to work perfect no sag or bounce when I load stuff in the back she is level in a mile or 2 I know I am not looking to replace them since they cost $300-$600 each depending on who is selling them. but its nice not to have a compressor.
Hitch Max Trailer Weight Max Tongue Weight
Weight Carrying 5000lb 600lb
Weight Dist 12000lb 1500lb
GVWR (7200LB)
GAWR FRT (3600LB)
GAWR RR (4000LB)
