Draggo's avatar
Draggo
Need Battery Help ASAP
We are camping this week and I'm having trouble with the batteries on the trailer. I have 2 12V batteries in parallel. Both batteries are 4-6 years old and I have not had any issues with them to this point.
One battery was on the trailer and it died after about 2 days of usage for just the refrigerator (the fridge was on gas so the battery only needed to power the thermostat, no one was using the trailer so the only other things that would have been on were the CO detector and the radio vampire draw. The battery was switched out with a second battery that was fully charged and that lasted about a day or less. So today around 3 PM I took one battery that tested at 12.3 volts and another that was at 12.9 volts and set them up in parallel which I have done many times before and always get a few days of usage out of them but about 4 hours later they are already both down to 10 volts.
I don't think it's a battery issue because they are both doing the same thing regardless of how they are hooked up and it would be pretty coincidental that both batteries went at once. It seems like something else is drawing the power down pretty quickly. I've dry camped like this for years and never had this happen before.
Any ideas? Thanks in advance.
Mike
  • First, a 6 year old battery is pretty old, next, connecting the 12.3v battery and the 12.9 in parallel bassically got you a pair of batteries limited by weakest battery in the pair.
    When batteries go bad they drain much faster than when new so it's likely that your actual amp hour capacity left in that bank is much less than when new and what you were used to.
    The 12v draw on a Dometic fridge is more than the thermostat, it's the ignition circuit and the 12v anti condensation heater that most Dometic frigs have. Open the frig door and feel the frame between the frig and the freezer...if it's warm it's running on 12v. There may be a switch for it up under the top power panel (you will need to open the freezer door to see it but many do not have a switch, the heater is always on.
    Water heater, mine has about .5 amp current draw.
    Plus there's the parasitic load of the co2 detector and possibly a few other things...usually between .5 and 1.5 amps.
    If I were to guess I would guess old batteries.
  • I would look at the water heater. I would also try to measure the current draw on the batteries.
    It seems something has changed to increase it batteries current draw.
