dvitale300's avatar
dvitale300
Need help - problem with water heater
Hi there,
We're going on a trip on Thursday and I'm experiencing a problem with our water heater. It is an Atwood model, 6 gal gas. We have a 2015 Starcraft 28BHS.
The heater worked fine last week. I noticed that there was some water leakage below the unit - and I realized tonight that I hadn't used plumbers tape when I re-attached the drain plug after de-winterization - which is now fixed.
When I turn the water heater on, I hear the click, click, click, and then the pilot fires and I can see a nice blue flame (like normal). The problem is that the clicking continues and then stops (after about 8 seconds), and the flame goes out. I get the failure warning light on the interior panel. This cycle occurs again about 2 more times, and then stops.
I unplugged the spade connectors (about 4 of them) and they were wet. I've left them unplugged to dry out - but am not sure if this is my issue. Any thoughts? help? I checked the flow of propane into the unit and it is just fine.
thanks - david
