theoldwizard1
Jul 22, 2017Explorer II
CoachmenKen wrote:
Ford specs are confusing:
I have the 7100# GVWR option seen on my window sticker
Payload 1870
GCWR 13,500
Max Loaded Trailer weight 8400
Sorry another spec sheet states 8100
Does the sticker specifically say it has the HD Tow package ? If not, then you probably do NOT have the HD radiator, auxiliary transmission cooler or 7 pin trailer connector.
These all can be added and should be if you are towing anything that is Class III (> 3,500 lbs).
What is the rear axle ratio ? Again, you should have a 3.73 or higher axle ratio if you are towing a Class III.
