Boband4
Aug 10, 2014Explorer
If i read correctly, 100% bench tested means going for extended run, uninstalled, with no shut down? If so, then it is really pointing to an obstruction in the installation. Looking to eliminate possibilities - have you confirmed the power quality? Any chance that as it loads down running the compressor it is overtaxing the system and going to a low voltage problem?
44,066 PostsLatest Activity: May 13, 2026
