JLTN_James wrote:
Ex-Tech wrote:
Beer Belly wrote:
BB_TX wrote:
Beer Belly wrote:
What are the ramifications of removing it:h
Eliminating overload protection and the possibility of melted wires and possible fire.
Won't the onboard fuse panel blow a fuse before anything fries ??
No. The dash fuses only protect the circuits they serve. Bypassing this breaker would negate protection of the circuit it serves, possibly the main battery feed.
I'm going to use the beloved (or hated) water pipe analogy here. Think of the water supply at a sticks & bricks house. If the only shut off valve was located 30' inside the building and the supply pipe breaks before that valve, how are you going to keep from getting flooded?
So, from your example, what is of concern is the wiring from the battery to the Fuse Panel. Guess I should try to find a part number or specs and wire up a new one.....Thanks
