enblethen wrote:
Low point would normally be the size of larger pipe in photo.
Low point drains the water when valve is open.
Have you tried to follow the small line?
Oh yeah, that is easy...each is about an 8 inch stub...not connected to anything, just open at the end. So, just a short piece of 1/4" tubing open at the free end. But, unfortunately, the one squirts quite a lot (almost free flow) when the pump is running, so I either need to plug the open end, or replace it. If it really has no use, then the fix would be much easier...just cut it out and replace with a straight section of PEX. Just don't want to do that if there is an actual use or need for it...must be there for a reason I'd think.
So, do you know where to look for the low point drains on a 2000 Lance 1121? I'll be out to the TC later today and will look around. Maybe near the gray/black dump as I would have to raise the TC to see that area...maybe that is why I haven't found them yet???
