jmoylesExplorerApr 26, 2014Need help with battery drain at ELX-30 converterI'm running into an odd issue that I'm not sure how to address. We recently bought a Starcraft 10RT PUP with a ELX-30 converter. After a few days I noticed the battery had gone flat on the PUP. A...Show More
jmoylesExplorerApr 26, 2014Pulling the reverse polarity fuse killed the drain. Pulling this fuse also killed the 12VDC LOAD CIRCUITS 1-3 as well.
Related ContentElixir ELX-30IOTA DLS-45 converter and LifePO4 batteriesAG battery switchoverConverting two 30amps to one 50amp for RV campingNo 12 Volt without converter
