BobsYourUncle
Aug 02, 2020Nomad
KD4UPL wrote:
The Duramax used thru 2016 was the LML. In 2017 they started with a new Duramax called the L5P. The L5P uses a Denso fuel system instead of a Bosch system. The old Bosch CP4 injection pump had a bad reputation for failures on both Chevy and Ford diesels. When the pump went out it generally took the rest of the fuel system with it. I would much prefer a 2017 or newer with the Denso pump. The L5P also gained 80 hp and 250 lb ft.
I am also astounded at the kind of money people pay for trucks. I've been shopping for a new work truck myself as my 2005 that I bought new now has 270,000 miles on it. Mine is still doing quite well but I know I'll need a new one before long.
When I build a crew cab diesel dually cab and chassis truck with 4wd exactly like I want it the sticker is about $56,000. The price from the dealer is around $49,000. When I look at used trucks the majority of them 5 years old or so are going for more than I can buy a new one for. I can't for the life of me figure out what you add to a truck that's worth an extra $30,000 over what I'm specifying.
That's good to know about the pump, thanks. Good information. I had to put a pump on mine at around 300,000K. Expensive...
The price difference Canada vs US is a lot. I built one last year similar to mine, a few more options but not everything and it was 84G Cdn. Hard to justify.
Boggles my mind the price of used trucks.
44,060 PostsLatest Activity: May 06, 2023
