TeeSmalls's avatar
TeeSmalls
Need Replacement Awning & Hardware
Hello! New to this forum and I wanted to see if you guys could help me out.
We just purchased a 2007 Starcraft Centennial 3604. The seller said that the last time they went out with it, a bad storm ripped off the awning and bent the poles so they just threw it away.
We'd really like to replace it but don't know where to go. I'll basically need everything associated with the awning since all that's left on the camper is the track to slide it on and the places for the poles to sit.
Any direction on where to go? And how much should I expect to pay for this?
Thanks!
  • Great, thanks everyone. Looks like the Carefree of Colorado unit might be my best bet. Thanks!
  • Dometic Trim Line might be a good choice. Relatively inexpensive.
  • This is on a pop up camper. Different set up than TT awnings. The longest roof that was produced in the last 20 years on a PUP is 16 feet, meaning you can only put a 15' awning on it. And it has to be of lighter construction that what goes on TTs as it is now part of the weight that gets cranked up when the roof is raised. That's why the awnings generally look anemic by most standards.
  • how long do you need it to be. just replaced my 16' with a 20' while I was in AZ. total cost 975.000
  • One of the more expensive places to get a replacement awning for aa pop up camper is direct from Carefree of Colorado. For $345 plus shipping, you can get a 9ft. wide awning, found at http://www.carefreeofcolorado.com/products/campout.html. Just get one that is 1 foot shorter than the length of your roof.
    There are also other options such as a "cabana" bit I can't find specifics right now on my phone.
  • You can probably pay from $600 to more than $2000 depending on size, options, configuration, etc.
    Here's a link to the Camping World website awning order page. You can put in different options and it will give you the price:
    Awning order page
    Jim
