bs49
Mar 06, 2017Explorer
mike/kellie wrote:
I have your truck (actually selling it) and a heavier camper. I would do the camper purchase and nurse the ride home with your stock set-up. I just have lower stable loads and anaftermarket sway bar. Towing is another conversation.
Thanks for your response. I will add the stable loads, air bags, and the Helwig rear sway bar. So you think I can carry the camper but may run into issues towing? I assume the Jeep will be fine since it is flat towing. I will be using a Superhitch with a SuperTruss extension. I would not think the tongue weight on my 16 ft tracker aluminum boat would exceed 300 lbs (I do have 4 heavy marine batteries up front).
