wanderingaimles
Mar 03, 2019Explorer
First off, have you verified that you have 12 volts to the aux pin?
Many manufacturers dont have the fuse in place to energize that wire.
Check the voltage before modifying, it wont be a lot, but you should get some charging even with the existing small wiring.
Also if you do decide to increase the wire size, verify that you have at least the same size ground lead.
44,065 PostsLatest Activity: Apr 14, 2026
