TwinTurbo's avatar
TwinTurbo
New 2016 F350 (Follow-Up Thread)
A couple of weeks ago, I posted a thread asking about "must have" options for a Ford F250/F350. For whatever reason, the thread has been deleted and the information contained within it has been lost. That's a shame, really, because it contained some useful info that I needed to reference and continue on with the discussion. But I digress...
I ended up purchasing a 2016 F350 SRW 4X4 Crew Cab Long Bed with the 6.7L Power Stroke in the Lariat trim level. The truck has the following options:
LT275/70R18E OWL All Terrain tires
3.55 Electronic Locking Axle
Chrome Package
FX4 Off Road Package
Navigation System
Rapid Heat Supplemental Heater
Engine Block Heater
Camper Package
Snow Plow Package
Roof Clearance Lights
Upfitter Switches
Tailgate Step
Lariat Interior Package
Bodyside Protection Moldings
The two options I wanted but did not get are the heated rear seats and the factory 5th wheel/gooseneck prep package.
So far, we love the truck. It rides well, is as luxurious as I could possibly want, and has a CCC of 3275 lbs. I am ready for camping season to begin! Well, almost ready...
I have a few questions I'm hoping you guys might be able to help with. In my last thread, I received some very thoughtful, very helpful replies that I never got to utilize or even say "thank you" for. So, here's what I'm dealing with now:
1. Our current travel trailer is relatively small with a 19ft. box and a GVWR of 3,500 lbs. and a tongue weight of roughly 420 lbs last I checked. It was previously towed with a 2013 Honda Pilot utilizing an Equal-I-zer hitch. Since the camper is so far below the towing and cargo capacities of my new truck, can I get by with just a regular drop hitch? Further, any recommendations as to a quality hitch? The F350 sits substantially higher than the pilot, and I'm completely lost as to which direction I should go regarding a new hitch. I know our current camper won't "push around" the new truck :)
2. In my last thread, someone stated that I didn't need the factory 5th wheel/gooseneck prep package because there are aftermarket solutions. Can anyone elaborate or this? This was one of my must have options, but I let it go because everything else was right with this truck. I prefer quality and clean over the cheapest possible solution. Any pros/cons to an aftermarket setup? Can the factory package be added after purchase?
3. I NEED MUDFLAPS! Preferably, I would like some no-drill mudflaps, but I really don't know which way to go, even after doing some research. How hard is it to install mudflaps that require drilling? And why do I read so much about needing brackets? Yes, mudflaps apparently confuse me, much to my dismay.
I thank you in advance for any input. All I have to offer is a measly and crummy pic of the new truck:
Oh, I originally planned on the standard bed. That's what we test drove and what I thought I ordered via dealer trade. When the truck showed up, it was the long bed variant, much to the surprise of my wife and I and our salesman. I had to stop signing papers and drive the truck back to my house in order to make sure it would fit in the driveway. Obviously, it did, and I love the long bed and large fuel tank. It all worked out better than I expected.
  • how about a big ole Congrats on the new truck.
    Do you have any idea what kind of hitch you are going with if you go Fifth Wheel?
    You can purchase the Reese Elite under bed rails which is the same thing that the Ford fifth wheel prep package is.
    Another option is the B&W Gooseneck and the Companion fifth wheel hitch.
    There are other options but the last I'd like to mention are the above bed fifth wheel "industry standard" bed rails which many like just fine.
    Thanks!
    Jeremiah
  • I had mud flaps installed on my Chevy (dully) after market. They simply unscrewed the large screws holding the fender well on, and attached them right there. No extra drilling (except through the mud flap to make the hole). Worked great! Looks factory installed. Maybe you can do the same. Not sure how your truck side is attached though.
    About your WD system. By the time you fill your tanks with propane, add the battery, and load the camper, your tongue will be heavier than you realize. Here's a thought, this is something I realized just a few weeks ago, after more than 40 years of towing experience.....
    If the back of the truck squats (any at all), the headlight angle will be higher! A real problem at night, but if your truck keeps the head lights on during the day too, this could be a real headache for on-coming traffic.
    Another thought... if by chance ... just a chance ... you are camped somewhere, and your truck has mechanical failure and you need to get your camper pull somewhere different by another truck, with your hitch, you can still use the WD on another vehicle. (peace of mind).
    Unless you are towing an open utility trailer, WD with sway control is still very much needed. You've invested so much into the new truck, and the camper, why not just go ahead and finish it right and be safe, and not sorry. You'll not regret it.
    Once you get truck and camper and WD system, go for a nice ride. Then remove the bars and go a little farther. I BET before you get 2 miles down the road, you'll be putting the bars back on,.... even with a 1 ton!
  • If you drill holes to install mud flaps, you're breaking the paint and undercoating sealants allowing rust to start forming on the bare metal of the holes you drilled. If they rust enough, the screws can loosen up and the mud flaps to drop off. If you get a new truck every 4 - 5 years, it's the next owner's problem.
    A lot of people will run a piece of metal, hooked to the frame rail, from one side to the other and fasten the mud flaps to it. This usually allows you to install stronger and larger mud flaps than those preformed to fit the wheel well.
    Bill
