JIMNLIN
Dec 04, 2013Explorer III
One reason state regs says the sum of the GAWRs can be the vehicles new GVWR along with points made already , is brakes are a function of the GAWRs according to NHTSA:
NHTSA says this about components of the GAWR:
"Gross Axle Weight Rating is the rated load-carrying capacity of an individual axle and wheel assembly. (It represents the load that may be steadily sustained by the components in the system; i.e., tires, rims, hubs, bearing, axles, brakes, suspension, sub frame, etc. with the GAWR limited by the components with the lowest working rating".
Here is a short snipped example of how a weight code may read and reference brakes/etc ;
Maximum gross weight for axles
7.16 (1) A person must not, without an overload permit, drive or operate on a highway a vehicle loaded or configured so that
(a) the gross weight on an axle exceeds the manufacturer's rated capacity for that axle or for the brake or suspension system with which the axle is equipped, ..........."snipped for length)
This from CA on declaring weights;
Declared Operating Weight
What are GVW and CGW?
3. Q - Can I declare an operating weight higher than my vehicle's Gross Vehicle Weight Rating (GVWR)?
A- Yes, but only if you are declaring the weight of your vehicle in combination with a towed vehicle and its load (the Combined Gross Weight). NOTE: A declared Combined Gross Weight does not authorize a truck without another vehicle in tow to exceed the truck's authorized axle weight limits."
