rjstractor
Dec 04, 2013Nomad
SoCalDesertRider wrote:
For some unkown reason, the camper certification weight is usually significantly less than actual payload capacity of the truck. It makes very little sense, but it is very common and has been for years.
Possibly they're accounting for the higher vertical center of gravity, and increased frontal area (height and width) of a truck camper load, versus a load of rocks, etc, of the same weight....
I think much of it has to do with where the axle is placed in relation to the bed space. In other words, in some trucks, namely crew cab trucks with shorter beds, it may be impossible to load the bed to the truck's max payload without overloading the rear axle. A slide in camper compounds this problem if the camper is longer than the truck bed since it will transfer weight off the front axle onto the rear.
44,071 PostsLatest Activity: Aug 08, 2026
