bloomis2925's avatar
bloomis2925
New battery, no power?
Spring has sprung and I put a new battery on our TT. Hooked the battery up and I have no power in the camper when on battery power. Shore power, everything works fine. Only thing that works on battery is the power tongue jack, but it is direct connect to the battery.
I checked all the fuses in the converter/ fuse panel, they are all good. Is there more fuses located anywhere else? I've crawled all over the camper looking for anything that may be the issue. I've also searched the forums, but put in "battery" and you get a lot of results.
Not sure if I am missing something simple or not.
Thanks for your help in advance!
