I have not tried the EBC yellow for truck, but I have used EBC yellow for cars. If its the same compound I will say you will love the performance of the pad, they really do step it up from OEM compounds. But if the truck compound is like the car compound you will NOT like the amount of dusting they create. I also found they wear out a lot faster. But they do not tear up the rotors, so on a car I was able to get two sets of pads to a rotor before they where worn below spec and needed replacement.
A friend uses the Hawk Superduty pad. It has great performance in the compound, no noticeable dusting over the OEM compound, but when they are cold they can squeal a bit. Once they warm up they never seem to have an issue. I been considering these or a step down to the Hawk LTS when I am due for pads probably around fall/winter timeframe before my big trip to FL.
