Huntindog
Jul 16, 2020Explorer
An often mentioned benefit is that nitrogen molocules are larger than oxygen.... So it does not leak thru the pores of the tire as fast.... probably true but..... Regular air is about 68% nitrogen, so according to this theory every time air is added to the tire the nitrogen % should increase.... IOW, even those that do not initailly have their tires filled with nitrogen soon end up with close to the same percntage as those that do! In short; their is very little benefit to having this done. Especially if one takes into account that the nitrogen filled tires are never 100% filled with nitrogen! That would require suctioning out all of the air before adding the nitrogen.... Which is impossible.
