Thermoguy
Jul 17, 2020Explorer II
Huntindog wrote:
An often mentioned benefit is that nitrogen molocules are larger than oxygen.... So it does not leak thru the pores of the tire as fast.... probably true but..... Regular air is about 68% nitrogen, so according to this theory every time air is added to the tire the nitrogen % should increase.... IOW, even those that do not initailly have their tires filled with nitrogen soon end up with close to the same percntage as those that do! In short; their is very little benefit to having this done. Especially if one takes into account that the nitrogen filled tires are never 100% filled with nitrogen! That would require suctioning out all of the air before adding the nitrogen.... Which is impossible.
Just Curious - how often are you adding air to your tires? I can go years and never add air. If you are adding air regularly, you might have a different issue you should look into.
