nickthehunter
Sep 04, 2023Nomad III
Yosemitebobr wrote:You won’t strain the existing wire. The wire is protected by the circuit breaker - that’s why you have circuit breakers.
Sense you added 5 additional outlets, keep in mind the total amps/wattage you are going to strain the existing wire which I assume is #14 that goes to a 15A circuit. Be on the cautious side when adding additional items. The LED will have little effect on the circuit.
