DutchmenSport
Feb 24, 2017Explorer
Huntindog wrote:
I think what you have is enclosed, probably heated tanks and valves. It appears that your black tank valve handle has been worked on or replaced. It should be on an extension that goes thru the under belly, which should be sealed up and the valve handle is accessable from under the underbelly. ...
Huntindog has it correct. The valve handles were originally on longer extensions. Previous owner probably had an issue and replaced the valve. The original valve handles probably looked similar to this:
