robsouth
Jun 26, 2013Explorer II
Check your water heater winterizing by pass valve to be sure it is in the correct position. Check the outside shower (if you have one) to be sure the water is turned off at the knobs and not just at the shower head. Both of these will cause water blending (cold and hot) and you will not get hot water like you should. Just a starting point.
