work2much
May 27, 2018Explorer
I like using circuit breakers instead of fuses as they can be used as a switch. You could replace the factory fuse between the solar charge controller and the Battery with a circuit breaker and shut down solar power to the bank this way. In addition I believe it wise to install a battery switch at the battery. This is much easier and safer way to kill battery power completely without having to put a wrench to the battery terminal.
