monkey44's avatar
monkey44
Nomad II
Mar 02, 2014
New Chevy 6.0L gasser -- Octane?
Just bought the new Chevy 2500HD with 6.0L gas ... and wondering what you guys run for octane.
And why you choose it? -- The 'why' is important too ... because it's not just about mpg, it's about engine performance and wear as well.
Doesn't bother me to buy higher octane as long as it benefits performance ... but am not sure if it makes a difference in the computer fuel management on these new 6.0L engines.
In the HD trucks - it does not offer the 'cylinder selection' option, so it always runs on all eight. The truck is 'labeled' a flex-fuel engine, but I don't really think that matters at this stage ... trucks have been flex-fuel for several years, without that label on the gas cap.
  • This makes me wonder about a lot of comments I've read in other places. I read that others buy gassers instead of diesels because the fuel is cheaper even though the diesels get better mileage. Today's fuel prices where I buy: Premium - $3.50, Diesel - $3.54.
  • Knock sensors never advance the timing. Timing is set at a base table and if knock is sensed they will retard the timing until knock is no longer sensed and then return to the base table.
    With modern computer control, engines are monitored so tightly that even slight changes in weather or altitude can make a difference in what octane to use for most efficiency. For instance, on a hot day at high altitude you will be able to get by with regular gas or on a cool or cold day you might have to use premium to keep detonation away. Same way with altitude. The closer you are the sea level the more octane you might have to run for best efficiency.
    As you can see, it can depended on a lot of things. Bottom line is, the OP is just going to have to try different octane fuels and see for himself what works best for his situation and engine.
  • I agree to just try it for three tanks and you will know based off real world testing.
  • I have 4,000 something on my 13 Ford 6.2, and the last 500 miles were towing with fresh 91 premium no alcohol. I was towing in fairly steep hills alot of those miles. It seemed to me that I had less down shifting, and an over all happier sounding engine.
    Imagination? Maybe, but I don't think so,
    Jerry
  • All modern engines with computers have "knock sensors" in them.. Even my 97 F150 5.4 had one and the computer uses the knock sensor to determine how much timing it can run.
    The theory is that if you run higher octane, the computer will advance the timing and therefore net you some more performance which can net you some mpg if you can still keep your foot out of it..
    I tried it on my 97 for about 3 tanks of gas running empty and didn't really notice any change.. I didn't do it towing because it ran fine on regular and @ 10 mpg, I didn't want to pay the 20/30 cents more per gallon.. :)
    I'm curious if it'll make a difference on my new Ecoboost, but so far I've only run regular and I've still not gone WOT with it, nor needed to yet... ;)
    Good luck!
    Mitch
  • I started running 91 octane gas in my motorhome because it performs better, and also better mileage. Test it for yourself.
    Fred.
